15 years agoYes, this definitely helps, thank you.
I guess what this means is that, in the future, if one of the FPGAs gets re-built, then I will need to run the report_datasheet and recheck the timing on the other FPGA to be sure all is still OK. Perhaps another approach is to use the set_max_delay and the set_min_delay constraints to put limits on either the Tco/Tco_min or Tsu/Th of the design to help flag an issue during future re-builds. Does this make sense? Martin
