15 years agoHi, Pletz and Cris72,
Thank you both. Yes, I know the usage of clock enable signal. If I write the code, I will also use it as a good synchronous design style. But, since I am not the author of the code and the whole design is near the final stage, I am not supposed to change the code a lot. I wonder if there is a way to contrain the current design without changing the code. It is really a headache.:mad:
