15 years agoHi wdshen,
With so low frequency clocks I use the solution that pletz suggests. Use Fc=15MHz as the single main clock. Generate low frequencies through enable pulses 1/Fc long rather than usual clock square waves with a 50% duty cycle. Use Fc to clock all your devices and apply the enable pulses to devices which need to run slower. Cris
