15 years agoHarris and Rysc :
Using Harris mini-project I did some work on TimeQuest with regard to actual implementation of set_output_delay figures and realised that the equations are correct directly for tSU/tH but not for tCO. The tCO is computed indirectly from tSU/tH as entered in the equations mentioned in this thread. Thus the final example that I posted its link is misleading or out of date or badly worded. Regarding skew: I found lowest data skew when I set all ten output registers to fast io
