15 years agoRephrasing, to make sure I have it right, but you're saying the external delay should be the same regardless of whether they invert the clock or not. I completely agree. But he said he's failing timing(I think that was said). The analysis of that is partially "are my constraints correct" and if they are, then "what's going on inside the FPGA that can't meet my constraints". It's the latter part I'm moving on to, i.e. I believe the constraints are right(except maybe that -invert) and I want to see what's going on in the FPGA that causes it to fail timing.
