15 years agoFYI, I always create a .tcl script called TQ_analysis that does something like:
report_timing -setup -npaths 100 -detail full_path -from [get_clocks ssync_ext] -panel_name "ssync_inputs||setup" report_timing -hold -npaths 100 -detail full_path -from [get_clocks ssync_ext] -panel_name "ssync_inputs||hold" I add this to the project directory and access it from the Scripts pull-down menu in TQ. It analyzes setup and hold on these input paths. You should see a 4ns setup relationship and a -4ns hold relationship. That means the transfer can handle +/-4ns of skew on the data. You'll then see 2ns iExt delays, whcih says +/-2ns of that relationship is chewed up by our external delays, leaving 2ns of skew for the FPGA. Again, you'll have to change the external values. (Also, I've typed everything but not run it, so there probably will be typos)
