15 years agoHaven't looked at the .zip, but does is the clock/data edge aligned or center-aligned coming from the AMCC chip? If it's edge-aligned, are you using a PLL to phase-shift the clock 90 degrees? (Constraints can change based on how it's implemented, naturally, so asking before writing out a quick example).
