10 years agoHow to constrain a parallel bus from a PLL clock?
Hi. I have a couple of questions about the my design. Basically I have an FPGA which has a big data table which the values are readed and sent to an external DAC. The reading process and the DAC are ...
10 years agoHi Dirk,
Thank you for reply. I understand now. And related the skewed version for the DAC clock, which is the required skew? I guess that is required an offset equal to all the delay internal in the FPGA plus board delays? I guess that 3 latency cycles is not a problem, but it is necessary to get the relationship between the DAC clk and the data outputs from the FPGA.
