10 years agoHow to constrain a parallel bus from a PLL clock?
Hi. I have a couple of questions about the my design. Basically I have an FPGA which has a big data table which the values are readed and sent to an external DAC. The reading process and the DAC are ...
10 years agoHi Frank,
specially a division in HDL takes a long time. You have to choose if you want to wait in clock cycles or in gate delay. In the altera cookbook there is a fast Radix 4 divider, that calculates 2 Bits within one clock cycle.That results in at least 16 clocks for a 64 / 32 division. If you use the "zero latency" Version it will use combinatorial logic only. In my experience you result in a relativ low core frequency in the 10MHz range. To make a division it is much faster to multiply with the inverse divisior. OK, this works only if the divisior is fix, or is changed slowly. You may add the "set_multicycle_path" to your design, which helps tha timequest is not complaining. But the design won't work if you are still feed the divider with data @ 100MHz. That would be no solution. To get a divider running with streamed data @ 100MHz i would suggest to create something like a pipelined divider. Or to multiply with the inverse divisior. The dsp blocks will easily handle 16 by 16 bits @ 100MHz.
