10 years agoHow to constrain a parallel bus from a PLL clock?
Hi. I have a couple of questions about the my design. Basically I have an FPGA which has a big data table which the values are readed and sent to an external DAC. The reading process and the DAC are ...
10 years agoDear Alex,
Thank you for the guidance to understand tis issue. I followed the Altera wiki and some guides. I constrained the output as is adviced but I have setup violations. I inserted the Timequest SDC cookbook lines:
create_clock -name CLOCK_50M -period 20.000
create_generated_clock
-name CLOCK_DDS_100M
-multiply_by 2
-source }]
# Specify the maximum external clock delay to the FPGA
set CLKs_max 0.5
# Specify the minimum external clock delay to the FPGA
set CLKs_min 0.5
# Specify the maximum external clock delay to the external device
set CLKd_max 0.5
# Specify the minimum external clock delay to the external device
set CLKd_min 0.5
# Specify the maximum setup time of the external device
set tSU 2
# Specify the minimum setup time of the external device
set tH 1.5
# Specify the maximum board delay
set BD_max 0.82
# Specify the minimum board delay
set BD_min 0.657
# Create the output maximum delay for the data output from the FPGA that accounts for all delays specified
set_output_delay -clock CLOCK_DDS_100M-max }]
# Create the output minimum delay for the data output from the FPGA that accounts for all delays specified
set_output_delay -clock CLOCK_DDS_100M-min }]
Related the data send to the DAC is fixed. I instantiated a ROM initialized by a .mif file. The problem is a setup violation for each DAC line (each bit) I attached the report file for the DAC[7] signal. I guess that the data can travel at 100 Mhz from the ROM output register to the output pin in less than 10 ns. For this I though in use a multicycle in order to allow 2 cycles to reach the output pin.
