17 years agoYes, location assignment for PLLs in Assignment Editor works, and seems to be necessary in some cases, where the compiler/fitter apparently isn't able to select the correct PLL automaticly, e. g. to drive a dedicated clock output. Here an example for a PLL component instantiated in a design entity timing, instance name pll1.
set_location_assignment PLL_3 -to "timing:pll1|altpll:altpll_component|altpll_mke1:auto_generated" The PLL naming scheme for your device (legal assignments) can be seen in Assignment Editor interactive entry, or learnt from the Quartus report resource section.
