NuvKFC
Contributor
4 years agoHow to change JTAG speed on programmer GUI
I'm using quartus17 and quartus13 version.
Some board needs to be slow down the pof file programming speed which use CFI flash device.
How to slow down the JTAG speed?
I can't find any set...
- 4 years ago
To change the JTAG clock frequency, Open Programmer tool, click on Hardware Setup. In the pop-up window, Hardware Settings tab, you can change the value in Hardware frequency field. See the attached screen shot.
Hope this helps.
Ash_R_Altera
4 years agoHi,
Hope this helps.
- NuvKFC4 years ago
Contributor
Hi Ash_R_Intel
Thank you, Ash_R_Intel, very much.
I'm using quartus17 lite and quartus13 standard version. I can't find the "Hardware frequency" in the Hardware Setup GUI.
Can I set it in other place?
Thank you very much.
