9 years ago
how to calculate sin inverse (ARCSIN) in VHDL?
I am using altera de0 nano soc fpga, and quartus 16.1 lite edition. I found that to calculate sin, cos and atan Altera's CORDIC IP core can be used.or lookup table (LUT) can be used for sin or cos .but how to get sin inverse (arcsin) in vhdl? is there a way to generate sin inverse?
i want perform below calculation in vhdl,
library ieee;
library ieee_proposed;
USE ieee.std_logic_1164.all;
use ieee.math_real.all;
use ieee_proposed.float_pkg.ALL;
architecture,
PROCESS(clk)
variable ph ,r ,l ,rp : float (4downto-27);
BEGIN
IF rising_edge(clk)THEN
ph := arcsin((r / l)* sin(rp);
ENDIF;
END PROCESS;
    Default Re: how to calculate sin inverse (ARCSIN) in VHDL?
    Why not just use a look up table like the rest?
    So there is no other way to calculate arcsin ? using CORDIC IP CORE?
    --- Quote Start ---
    --- Quote End ---
    can you link a better lookup table here? I found one from this altera forum, it is 12 bits, 0-4095 sampled sine wave and cose wave.
    You can create your own LUT, with values filled using your own values, to as many bits as you want.
    In VHDL - create a constant that contains all of the values - look into Altera's VHDL coding guidlines on how to infer rom, and populate it with your own values.
    --- Quote Start ---
    --- Quote End ---
    Is there any easy way to create my own LUT?like using matlab?
    You can calculate the table initialization in VHDL, using ieee.math_real.arcsin.
    --- Quote Start ---
    --- Quote End ---
    I made a lookup table using excel and i put values in to switch case. and i get overlaps when accessing sin inverse. because when getting inverse of sine we point to a place at sin wave and get the phase of it. since sin wave is increasing and decreasing uniquely i get same amplitude levels twice when it increasing and decreasing. how to solve this. ?
    I would recommend to use a integer based Version of the cordic.
    andraka's cordic paper (http://www.andraka.com/files/crdcsrvy.pdf) discusses how to do this. You basically create a cordic (http://zipcpu.com/dsp/2017/08/30/cordic.html), input a vector of your input value, and rotate it until the input value reaches (1,0).
    Personally, I find the arctan form (http://zipcpu.com/dsp/2017/09/01/topolar.html) of the cordic (http://zipcpu.com/dsp/2017/08/30/cordic.html) more useful, as it doesn't struggle with scale issues and the output doesn't struggle with angular ambiguities.
    Dan
