9 years agohow to calculate sin inverse (ARCSIN) in VHDL?
I am using altera de0 nano soc fpga, and quartus 16.1 lite edition. I found that to calculate sin, cos and atan Altera's CORDIC IP core can be used.or lookup table (LUT) can be used for sin or cos .b...
9 years ago --- Quote Start --- You can create your own LUT, with values filled using your own values, to as many bits as you want. In VHDL - create a constant that contains all of the values - look into Altera's VHDL coding guidlines on how to infer rom, and populate it with your own values. --- Quote End --- Is there any easy way to create my own LUT?like using matlab?
