12 years ago --- Quote Start --- why dont you want to add extra latency? the latency will not affect the throughput. This sounds like you are using DSP instantiations directly to get the design at a low level, rather than infering the multipliers?? --- Quote End --- No it isn't. Just the other way round. Everything is inferred in that filter. Now I wonder, why the tools are not able to place the systolic registers outside the DSP when going over to a new column of DSP blocks and inside in all other cases. Instead, it just says "can't fit".
