How to avoid delay
Hello everyone,
My problem is that i have an output available at a current clock cycle and i need to be read at the same clock cycle by another register. My top level entity is where i instantiate components but the problem is exactly in this code :library ieee;use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_signed.all;
use ieee.math_real.all;
library std;
use work.MIN.all;
entity labeling is
generic(
LABEL_WIDTH : integer;
PIX_WIDTH : integer );
port(
clk_proc : in std_logic;
reset_n : in std_logic;
------------------------- in flow -----------------------
in_data : in std_logic;
in_fv : in std_logic;
in_dv : in std_logic;
p00u : in std_logic;
p01u : in std_logic;
p02u : in std_logic;
p10u : in std_logic;
p11u : in std_logic;
p12u : in std_logic;
------------------------ out flow -----------------------
out_fv : out std_logic;
out_dv : out std_logic;
------------------------ labels --------------------------
north_LABEL , west_LABEL : in std_logic_vector ((LABEL_WIDTH-1) downto 0);
north_west_LABEL , north_ouest_LABEL : in std_logic_vector ((LABEL_WIDTH-1) downto 0 );
current_LABEL , Label_to_merge , Label_instead : out std_logic_vector ((LABEL_WIDTH - 1) downto 0);
need_to_merge, need_to_resolve: out std_logic ;
number_of_object : out natural
end labeling;
architecture arch of labeling is
------ ------------------signaux pour les étiquettes-------------------------------------------------------------------------------
signal north ,west : integer :=0;
signal north_ouest , north_west : integer:=0;
signal curr : integer;
signal L_to_merge , L_instead : integer:=0 ;
signal merge , resolve : std_logic;
Begin
north <= to_integer ( signed( '0' & (north_LABEL)));
west <= to_integer ( signed( '0' & (west_LABEL)));
north_west <= to_integer ( signed( '0' & (north_west_LABEL)));
north_ouest <= to_integer ( signed( '0' & (north_ouest_LABEL)));
-------------------------------------- labeling---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
process(clk_proc,reset_n)
variable new_label : integer:= 1 ;
variable n_objects : integer := 0 ;
begin
if (reset_n = '1' )then curr <=0;
elsif (rising_edge(clk_proc))then
if ((in_fv and in_dv )='1' ) then
if (in_data= '0')then
curr <= 0;
merge<='0';
else
if (p01u = '1') then
curr <= north;
merge<='0';
else
if (p02u='1') then
if (p00u ='1') then
merge <='1';
curr<= minimum(north_west,north_ouest);
L_to_merge <= maximum (north_west,north_ouest);
L_instead <= minimum(north_west,north_ouest);
else
if (p10u ='1') then
merge <='1';
curr<= minimum(west,north_ouest);
L_to_merge <= maximum(west,north_ouest);
n_objects := n_objects - 1 ;
else
curr<= north_ouest;
merge<='0';
end if;
end if;
else
if (p00u ='1') then
curr <= north_west;
merge<='0';
else
if (p10u ='1') then
curr<= west;
merge<='0';
else
curr<= new_label;
new_label:= new_label+1;
n_objects := n_objects + 1 ;
merge<='0';
end if;
end if;
end if;
end if;
end if;
if (merge='1' and north_ouest=minimum(north_west,north_ouest)) then
resolve<='1';
else
resolve<='0';
end if;
if merge='1' then
end if;
end if;
end if;
report "The number of objects is " & integer'image(n_objects);
number_of_object<=n_objects;
end process;
current_LABEL <= std_logic_vector(to_signed(curr,LABEL_WIDTH));
Label_to_merge<= std_logic_vector(to_signed(L_to_merge,LabEL_WIDTH));
Label_instead<= std_logic_vector(to_signed(L_instead,LabEL_WIDTH));
need_to_merge<=merge;
need_to_resolve<= '1' when merge='1' else
'0';
end arch; Where the signal current_LABEL takes always the previous values of North, North_ouest, North_est and west instead of the current values . Ps: The North, North_ouest, North_Est and West values are provided by another module.12 Replies
I dont think I really follow what the problem is. Do you just want an unregistered output?
I'am simply looking for reading a value in a module during writing it from another module. Is that even possible?
Anything is possible
Why not just pass the data through without registering it? or just produce the data in parallel. did you draw a circuit diagram before writing the code'? - Altera_Forum
Yes i did otherwise i wouldn't be able to write anything. But could you please explain it to me how is it possible to just pass the data without registering it ?
Yes - do the calculations in an unclocked process. But be aware that this may decrease your fmax.
Why not simply register the output of the other module? - Altera_Forum
Yes i did try to omit the process and do the caclculation but the result got worsened. About register the output , in fact the output of the first module is the input of the second one and the output of the second module is the input of the first one. And it must be like that unfortunately..
Here is exactly what i'm implementing
https://www.alteraforum.com/forum/attachment.php?attachmentid=13026 . The Lx is provided by another module and the calculation of Lx depends on the four registers LA to LD . - Altera_Forum
Just pass lx in to generate la to ld and also delay lx separately
I am sorry i'm newbie to vhdl what's exactly to generate why did you choose it as solution exactly ?
