PhilipJ451
7 years agoHow to automatically generate Hexout file
Hi, please can someone help me before I go nuts!! I have a project that when I compile in Quartus Prime Lite (version 17) it always produces a hexout file. I use this file so my host CPU can download...
MEIYAN_L_Intel
7 years agoHi,
I found out that the hexout file can be generated through the Assignments -->Compilation Process Settings --> Device/Board -->Device and Pin Options --> Programming Files, tick to the box "Hexadecimal (Intel-Format) Output File (.hexout)".
The start address must be entered as a hexadecimal value.
Then compile the design file. A hexout file will e generate and can be seen in the output file folder.
If the problem still persist, please tell me as well.
