How to apply set_disable_timing SDC command before synthesis?
Means that you possible to see node c after synthesis? Probably can include node c in sdc after synthesis. Or using wildcard.
I believe sdc constraints like set_disable_timing will be processed at timing analysis stage.
Sheng
- NuvKFC2 years ago
Contributor
Thank you, ShengN, very, very, mhch.
No, I get a problem. Sorry about that.
I'm a Quartus GUI user.
Before getting off work, I click start compilation. Then next day, I can check the result.However, "start compilation" button will continuous do Synthesis, Fitter, Timequest, and Assembler.
The next day, I only can see the result that after Fitter.
So, I only can find the "cell|datac" where is the node c location in the Chip Planner after Fitter.
Could you please tell me how to find the specified node after Synthesis?.
