How to add a qip file to project using Makefile
I like to have the project file untouched unless I make an active decision to add something, so I create the project file using make.
The first instance of the project file is created by quartus_map and I can later add pin declarations etc using quartus_sh.
But I have not found a good way to add an IP block, qip-file, to the project in time since quartus_map need all files to be available.
How can I solve this?
I'm currently using:
quartus_map project_name --analysis_and_elaboration --family=... -f sourcefiles.args
- Joakim
I found out that I can create a qsf/project file by first creating an empty file followed by quartus_sh -t settings.tcl.
I use settings.tcl for pin assignments, but normally specified the source code to quartus_map.
The problem is that quartus_map will not read the qsf file before it has processed all the source files listed as argument to quartus_map, which will make it fail since it misses the qip file.
I'm running out of ideas...
- KhaiChein_Y_Intel
Hi Joakim,
You may add the following in the .qsf file
set_global_assignment -name file.qip
- Joakim
Thanks, but I do not have any .qsf file when running quartus_map.
The whole purpose of using a makefile is that it will create dependencies, adding source files etc, so it should create the qsf file from scratch.
- KhaiChein_Y_Intel
Hi Joakim,
The .qsf file has to be created first and then add the source file in the .qsf file.
- Joakim
Thanks KYeoh,
Yes, that is my question. How can I do that using the quartus tools?
Or do I have to create the qsf file manually?
Will create a qsf file with the source files I want, together with some settings like the chip family. But the command will fail when the source files are using components from the qip file and I have not found any good way to add the qip file when calling quartus_map or before it is called.
The Quartus GUI is calling Info:
quartus_map --read_settings_files=on --write_settings_files=off ...
So I have tried to create an empty qsf file with just the qip reference, with variants of the read/write_settings_files, but it seems like the settings file is not read until it has processed the source files in the argument.
BR / Joakim
- KhaiChein_Y_Intel
Hi Joakim,
The .qsf file is generated by the software automatically when the project is created.
- First, you may create the project file using project_new [-family ] [-overwrite] [-part ] [-revision ]. This creates a .qpf file and .qsf file.
- Modify the .qsf file to add the .qip file and all source files using set_global_assignment
- Run Analysis and Synthesis using quartus_map (Standard) or quartus_syn(Pro)
