How to add a qip file to project using Makefile
Hi Joakim,
The .qsf file has to be created first and then add the source file in the .qsf file.
- Joakim7 years ago
Thanks KYeoh,
Yes, that is my question. How can I do that using the quartus tools?
Or do I have to create the qsf file manually?
quartus_map project_name --analysis_and_elaboration --family=... -f sourcefiles.args
Will create a qsf file with the source files I want, together with some settings like the chip family. But the command will fail when the source files are using components from the qip file and I have not found any good way to add the qip file when calling quartus_map or before it is called.
The Quartus GUI is calling Info:
quartus_map --read_settings_files=on --write_settings_files=off ...
So I have tried to create an empty qsf file with just the qip reference, with variants of the read/write_settings_files, but it seems like the settings file is not read until it has processed the source files in the argument.
BR / Joakim
