Joakim
7 years agoHow to add a qip file to project using Makefile
I like to have the project file untouched unless I make an active decision to add something, so I create the project file using make. The first instance of the project file is created by quartus_map...
KhaiChein_Y_Intel
7 years agoHi Joakim,
You may add the following in the .qsf file
set_global_assignment -name file.qip
- Joakim7 years ago
Thanks, but I do not have any .qsf file when running quartus_map.
The whole purpose of using a makefile is that it will create dependencies, adding source files etc, so it should create the qsf file from scratch.
