13 years ago --- Quote Start --- But i need simulate a low frequency signal (about 100Kbps) --- Quote End --- Why would you try using the transceiver at such a low frequency? If the signal is AC coupled, then it probably will not even work. Describe what you are trying to do, and members on this forum can provide constructive feedback. Perhaps an alternative solution would be more appropriate. Cheers, Dave
