How TimeQuest analyzes path though the latch?
I am sorry for the late response.
Timing Analyzer found latches across multiple look-up tables (LUTs), or latches that do not include an enable (e.g. SR latches). The Timing Analyzer does not support analyzing this latch implementation as a synchronous element, but treats these latches as a combinational loop.
It is recommended to design without the use of latches whenever possible. You have to implement these latches with registers using asynchronous load and data signals, or remove these latches from your design.
You may refer to Intel Quartus Prime Pro Deisgn Recommendation User Guide https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-design-recommendations.pdf (Chapter 1.5.3 Latches)
Please let me know if you have any questions.
- Ruturaj_D_Intel7 years ago
Hi, Thank you for clarification. I do have one more follow up question; my understanding is that for timing analysis of latch as synchronous element, enable signal needs to be defined as latch. I could not find document describing this requirement and how to define clock on enable signal. Is there a doc which talks about how to define clock on enable signal for STA? Other question is regarding flop with asynchronous load; does Startix10 FPGA support implementation of flop with asynchronous load. Thanks, Ruturaj.
