8 years agoHow OpenCL synthesizes hardware on FPGA
Hi, I have some doubts concerning how OpenCL synthesizes hardware into FPGA. Both in single work-item and NDRange kernels, in the "vector_add" example (available on https://www.altera.com/support/...
8 years agoI read all the topics you gave me and I also read the section 1.3 of Intel FPGA SDK for OpenCL Best Practises Guide but I still have some doubts. If I am using a single work-item kernel to do a vector add, as in the example, I know that the loop iterations are pipelined but how can I know the hardware that is synthesized inside the FPGA? If I see the images in the best practises guide it seems there is just one adder,two registers for loading and one for storing. Is it the real hardware created inside the FPGA? If yes then the data for the operations can be acquired by accessing N times to DDR (for global variables). Thanks
