16 years agoInferring multiupliers is usually fine, aslong as you stay within the hardware limits (which for all Altera FPGAs is 18 bits per input - you can do up to 36 bits per inputs but you'll see your multipliers dissapear quite quickly)
It should pick up registers from the code that are contained inside the DSP slice too.
