8 years agoHow does the producer, consumer, and manager strategy in the programming guide work?
In Intel FPGA SDK for OpenCL programming guide Page 43, a producer, consumer and manager strategy is mentioned. There is also reference code for producer. __kernel void __attribute__((task)) ...
8 years agoThanks for the suggestion.
I implemented a design filtering a stream of data as you suggested using non-blocking channel. (Basically the design scans the input data and selects data that is larger than 10, then the selected data is multiplied by a constant. Finally, the result is written back to memory. ) It works as expected. I have the kernel code attached in case people in the forum may be interested. Also the code seems to be a bit complex, so it will be appreciated if you have more efficient implementation. Some minor questions: When I use the flag_valid as the end of the condition in k1 and k2, Some of the data in the tail is not handled. Basically it indicates that when the flag_valid is captured in k1, the data in ch01 has not been processed. Even though I tried to add memory fence in the code, the result remains wrong. I don't actually understand this part.
channel int ch01 __attribute__ ((depth(16)));
channel int ch12 __attribute__ ((depth(16)));
channel int k0_end __attribute__ ((depth(4)));
channel int k1_end __attribute__ ((depth(4)));
// Read data from DDR
__kernel void __attribute__((task)) k0(
__global const int* restrict src,
const int num)
int i;
for(i = 0; i < num; i++){
bool success = false;
do{
success = write_channel_nb_altera(ch01, src);
while(!success);
//printf("%d data is sent to ch01\n", i);
//mem_fence(CLK_GLOBAL_MEM_FENCE | CLK_CHANNEL_MEM_FENCE);
write_channel_altera(k0_end, 1);
// Filtering
__kernel void k1(
const int threshold,
const int cons)
bool flag_valid = false;
bool data_valid = false;
int flag = 0;
int data;
int count = 0;
int total = 0;
while(true){
data = read_channel_nb_altera(ch01, &data_valid);
if(data_valid){
total++;
if(data > threshold){
data = data * cons;
count++;
// write to channel12
do{
success = write_channel_nb_altera(ch12, data);
while(!success);
int tmp = read_channel_nb_altera(k0_end, &flag_valid);
if(flag_valid) flag = tmp;
if(flag == 1 && data_valid == false){
//mem_fence(CLK_CHANNEL_MEM_FENCE);
write_channel_altera(k1_end, 1);
break;
//printf("%d data go through the filter\n", total);
//printf("%d data is changed.\n", count);
// Write data to DDR
__kernel void __attribute__((task)) k2(
__global int* restrict dst
int flag = 0;
int data;
int idx = 0;
while(true){
data = read_channel_nb_altera(ch12, &data_valid);
// write data to DDR
if(data_valid){
dst = data;
idx++;
int tmp = read_channel_nb_altera(k1_end, &flag_valid);
break;
//printf("%d data is written to memory.\n", idx);
Cheng Liu
