8 years agoHow does the producer, consumer, and manager strategy in the programming guide work?
In Intel FPGA SDK for OpenCL programming guide Page 43, a producer, consumer and manager strategy is mentioned. There is also reference code for producer. __kernel void __attribute__((task)) ...
8 years ago --- Quote Start --- However, a simple regular opencl channel should be able to to the same thing, I don't see there is any reason using this design. --- Quote End --- If you need a shared buffer that is too big to fit on-chip, you can use this design because here, the shared buffer is stored in global memory. If, however, you can get the job done with a small buffer and the latency between the writes from producer and reads from consumer is small, then a standard on-chip channel can do the job just fine. --- Quote Start --- 1) Is there a way to do on-chip communication between two kernels using OpenCL when the amount of data communication is not determined at compilation time. You may take the simple filter as an example. Kernel 0 filters input data streams and extracts the data that is larger than 10. Kernel 1 gets the output data of Kernel 1 and does some processing. --- Quote End --- Yes, you can use non-blocking channels. These channels provide a flag using which you can determine if the non-blocking read/write has been successful or not. You can wrap your channel operation in a while(1) loop and use the flag, or even the data received from channel, to break out of the loop. You can find multiple basic examples in Altera's documents. --- Quote Start --- 2) Will the producer, consumer and manager scheme work for the filter example? If not, when will it be used to replace the basic on-chip channel based design? --- Quote End --- Similar to above, you can also use non-blocking channels with this type of design where the shared buffer is in global memory.
