How do I fix my Stratix V GX FPGA Development Kit after programming the MAX V control chip on the board?
Hi
Thanks for your update. Could you try on this? Perform the BTS test with Quartus v.12.0 as recommended in web and try to recover the board.
1. Step 1 : set all DIP switch back to factory default state
2. Step 2 : recover the corrupted Max V image with default pof file from BTS
3. Step 3 : Then you can try detect and program SV FPGA again
Also make sure installed the SV device database in Quartus installation to be able to detect the SV device on board.
- JWrig256 years ago
Hi, whenever I open the Board Test System, it gives me the error "Connecting to the target... java.lang.Exception: No USB Blaster detected. Please check connections and restart the program". I therefore cannot click on any of the Configure menu options and the BTS is useless. When I try to program on Quartus, it will recognize the USB_Blaster II but gives me the error "Unable to scan device chain. On-board programming hardware is disabled". I have checked to make sure the DIP switches are in the factory default settings. I am on my second FPGA board since the first one is corrupted as I mentioned earlier and now the second one has stopped working as far as being programmed to. Both of these boards give me these errors and I have no idea why and no idea on how to fix it because every method of fixing it requires that the device is programmable or able to connect to the BTS or Board Update Portal.
