- You need a Quartus subscription license
- Under Tools/Options/General/Processing/Parallel Compilation, you can set the number of CPUs used for compilation. - Altera_Forum
I have got the license.
And also set the parallel compilation to "all available processors" :confused: But it still use only one core. My OS is windows sever 2003. - Altera_Forum
--- Quote Start --- I have got the license. And also set the parallel compilation to "all available processors" :confused: But it still use only one core. My OS is windows sever 2003. --- Quote End --- Hi, I'm not a real OS expert, but did your OS recognize all your CPU's ? Is Windows Server 2003 supported by QUartus ? Kind regards GPK - Altera_Forum
Did you check "Flow elapsed time" in compilation report?
--- Quote Start --- Did you check "Flow elapsed time" in compilation report? --- Quote End --- I have checked , when fitting the Quartus "average processors used" is 2.1:)
