16 years agoDSP Builder is probably calling vsim based on whatever is on your PATH environment variable. try opening a command prompt and typing vsim. if Active-HDL pops up you'll need to edit Active-HDL out of your PATH environment variable (Start => Control Panel => System => Advanced => Environment Variables). check the User and System variables for the Aldec path and remove it. make sure the ModelSim path is present.
