15 years agothat's true, but even if you count the number of RAM blocks in the device you'll run into no-fit based on the problem i described
for example the 3c25 has 66 M9K blocks. running each in 256x32 for a Nios system (so 16,896 words), you won't be able to use all 66 blocks unless you wrap your own RAM logic
