15 years agonote that ram %bit usage figure is very misleading. if the smallest block in your device is 9k bits then "use one single bit and the whole block is gone". ram blocks also have limitations on datawidth and if you wanted wider data then it connects several blocks together and may waste a large number of blocks. if you target optimum width you may save resource.
