13 years ago --- Quote Start --- you should only need to map those libraries once. It should place them in the modelsim.ini file --- Quote End --- Thanks, so that means everytime I run modelsim, then these libraries will be automatically mapped to my working library. I will try to use command, if I have questions, I will post here. Thanks.
