JKate2
7 years agoHow can I get a Max+plusII 10.2 BASELINE license ?
link (below) for self-licensing of Maxwork is BROKEN; https://fpgasupport.intel.com/AlteraLicensing/license/index.html. Other attempts: I have entered both the Ethernet adapter address: 98FA9B0EBF...
AR_A_Intel
7 years agoHello
Welcome to INTEL forum. We are having intermittent problem with our Sign On systems. Due to ongoing issues you could sign/login using link
JKate2
7 years agoStill doesn't work
I received same response:
There is an issue in generating the license for this provided NIC/Host ID: 98FA9B0EBFB5
Please check your NIC/Host ID and try again. If you still encounter problems, please contact our customer support.
Why don't you try with same NIC ID ?
John Kates
