RSher11
6 years agoHow can I fix issue with JTAG programming mode?
When I was working with my project I’ve got a problem. In the project NIOS II software was loaded from EPCS device into DDR II memory chip. ELF was converted to HEX by the following script: #! /bi...
JohnT_Altera
6 years agoHi,
Currently due to the flash issue, you will need to change the MSEL so that it will avoid FPGA to be programmed through AS mode. This is so that you are able to reprogrammed the flash with the working jic.
