RSher11
6 years agoHow can I fix issue with JTAG programming mode?
When I was working with my project I’ve got a problem. In the project NIOS II software was loaded from EPCS device into DDR II memory chip. ELF was converted to HEX by the following script: #! /bi...
JohnT_Altera
6 years agoHi,
May I know if it is possible to change the MSEL setting? I would recommend you to change the MSEL to non-AS mode before powering up the board. After the board is power up, switch the MSEL to AS mode and performed JIC programming.
