13 years ago
How can I detect vector changes in other processes?
Hi All,
I’d like to experiment with various frequency & duty cycles to control a little motor with PWM. I’m using a DE0 devboard and the frequency & duty cycles are user programmable with the switches. My problem is that I don’t know how to reset my signals to 0 when either SW_FREQUENCY_SELECT_VECTOR or SW_DUTY_CYCLE_VECTOR is changed ( devkit switches are toggled) .
My code:
LIBRARY IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
--FREQUENCY CALCULATION
--50 000 000 50MHz
-- 1 000 000 1MHz
-- 20 000 20kHz
--50 000 000 / 20 000 = 2500 "0000100111000100"; - 20kHz
--250000ns
--250us
-- 0 000 100Hz 500000 "1111010000100100000"
-- 1 001 1000Hz 50000 "0001100001101010000"
-- 2 010 2200Hz 22727 "0000101100011000111"
-- 3 011 5000Hz 10000 "0000010011100010000"
-- 4 100 10000Hz 5000 "0000001001110001000"
-- 5 101 15000Hz 3333 "0000000110100000101"
-- 6 110 22000Hz 2272 "0000000100011100000"
-- 7 111 32000Hz 1562 "0000000011000011010"
--DUTY CYCLE CALCULATION
-- duty_cycle_stop = ( SW_FREQUENCY_VECTOR / 100 ) * SW_DUTY_CYCLE_VECTOR
-- example
-- 1250 = ( 2500 / 100 ) * 50
ENTITY PWM5 IS
PORT(
CLK : IN STD_LOGIC ;
LED0,LED1,LED2 : OUT STD_LOGIC ;
SW_VECTOR : IN std_logic_vector(9 downto 0);
BUTTON0,BUTTON1,BUTTON2 : IN STD_LOGIC ;
GPIO0_PIN2,GPIO0_PIN4 : OUT STD_LOGIC
END PWM5;
architecture PWMARCH of PWM5 is
alias RESET : STD_LOGIC is BUTTON0;
alias PWM_PIN : STD_LOGIC is GPIO0_PIN2;
alias SW_FREQUENCY_SELECT_VECTOR : std_logic_vector(2 downto 0) is SW_VECTOR(9 downto 7);
alias SW_DUTY_CYCLE_VECTOR : std_logic_vector(6 downto 0) is SW_VECTOR(6 downto 0);
signal count,duty_count : integer:=0;
signal duty_cycle_stop : integer:=0;
signal duty_cycle : STD_LOGIC;
signal SW_FREQUENCY_VECTOR : std_logic_vector(18 downto 0) :="0001100001101010000"; -- 1 50000 1000Hz
begin
--process(SW_FREQUENCY_SELECT_VECTOR,SW_VECTOR )
process(SW_FREQUENCY_SELECT_VECTOR)
begin
case SW_FREQUENCY_SELECT_VECTOR is
when "000" =>
SW_FREQUENCY_VECTOR <= "1111010000100100000"; -- 0 500000 100Hz
when "001" =>
SW_FREQUENCY_VECTOR <= "0001100001101010000"; -- 1 50000 1000Hz
when "010" =>
SW_FREQUENCY_VECTOR <= "0000101100011000111"; -- 2 22727 2200Hz
when "011" =>
SW_FREQUENCY_VECTOR <= "0000010011100010000"; -- 3 10000 5000Hz
when "100" =>
SW_FREQUENCY_VECTOR <= "0000001001110001000"; -- 4 5000 10000Hz
when "101" =>
SW_FREQUENCY_VECTOR <= "0000000110100000101"; -- 5 3333 15000Hz
when "110" =>
SW_FREQUENCY_VECTOR <= "0000000100011100000"; -- 6 2272 22000Hz
when "111" =>
SW_FREQUENCY_VECTOR <= "0000000011000011010"; -- 7 1562 32000Hz
-- will never reach this
when others =>
end case;
end process;
-- Update duty cycle
--process(SW_DUTY_CYCLE_VECTOR,SW_FREQUENCY_VECTOR,SW_FREQUENCY_SELECT_VECTOR,SW_VECTOR)
process(SW_DUTY_CYCLE_VECTOR,SW_FREQUENCY_VECTOR)
begin
-- duty_cycle_stop <= ( SW_FREQUENCY_VECTOR / 100 ) * SW_DUTY_CYCLE_VECTOR;
duty_cycle_stop <= ( conv_integer(SW_FREQUENCY_VECTOR) / 100 ) * conv_integer(SW_DUTY_CYCLE_VECTOR);
end process;
-- main process
process(CLK)
begin
if(RESET = '0') then
count <= 0;
duty_count <= 0;
duty_cycle <='0';
elsif(CLK'event and CLK='1') then
count <= count +1; --increment counter.
--see whether counter value is reached,if yes turn on the duty cycle
if(count >= conv_integer(SW_FREQUENCY_VECTOR)) then
count <= 0;
duty_count <= 0;
LED2 <='1';
PWM_PIN <='1';
duty_cycle <='1';
end if;
-- Duty cycle
if ( duty_cycle = '1' ) then
duty_count <= duty_count +1;
-- keep duty cycle high until duty_cycle_stop is reached
if(duty_count = duty_cycle_stop ) then
LED2 <= '0';
PWM_PIN <='0';
duty_cycle <='0';
end if;
end if;
end if;
end process;
end PWMARCH;
James
    register them, and then look for a rising or falling edge on inside the clocked process:
    if rising_edge(clk) then
      if input = '1' and input_reg = '0' then --rising edge
        --reset
      end if;
      input_reg <= input;
    end if;
    Hi Tricky,
    Your solution would work if I was looking for a change in a STD_LOGIC but I need to detect changes on STD_LOGIC_VECTOR. Shall I check rising or falling edges on every bit in a vector?
    If you don't care about whether its a rising or falling edge can't you just use the /= operator (reg /= input)? Not sure how fast you are clocking the register but if it is a slow clock I think this would be fine.
    The solution is exactly the same: register it and use the inequality:
    if input /= input_reg then
