15 years ago
Homemade TestBench attmept
Hola All,
I recently made a vhd file from scratch that tested some simple logic circuits successfully. All I have had as resources in this task is the tutorial files from ModelSim (counter.vhd, and tcounter.vhd), and a single text on vhdl (Circuit Design with VHDL by Peroni). Things were looking good until I attempted to make and test a frequency divider.
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs148.snc4/36780_10150214314760055_754135054_13023800_1551964_n.jpg
This frequency divider has one input (clk) and two outputs (out1, and out2). The code for this divider is below as well as the testbench I made for it. The problem is I get an undefined signal coming out of both my outputs. Any explanation as to why would be much appreciated.
Thanks for the assist,
Triston
****************************Freq Divider code*******************************
Library ieee;
Use ieee.std_logic_1164.all;
Entity Freq_Div_1 is
Generic(n : integer := 4);
Port(
clk : IN std_logic;
out1,out2 : buffer std_logic
End Freq_Div_1;
Architecture Div of Freq_Div_1 is
Signal count1 : Integer Range 0 to 7;
Begin
Process (clk)
Variable count2 : integer range 0 to 7;
Begin
if (clk'EVENT and clk='1') then
count1 <= count1 + 1;
count2 := count2 + 1;
if ( count1 = n) then
out1 <= not out1;
count1 <= 0;
end if;
if(count2 = 2) then
out2 <= not out2;
count2 := 0;
end if;
end if;
End Process;
End Div;
*************************** My TestBench Debacle *************************
Library ieee;
Entity tFreq_Div_1 is
Port(
End tFreq_Div_1;
Architecture testBench of tFreq_Div_1 is
-- ******** Component ******** ----->
Component Freq_Div_1
Port(
clk : in std_logic;
End Component Freq_Div_1;
--**** Test Signals ******* -------->
Signal clk : std_logic :='0';
Begin
dut:Freq_Div_1
Port MAP
clk => clk,
out1 => out1,
out2 => out2
clk_In : Process
Begin
wait for 10 ns; clk <= not clk;
End Process clk_In;
intialize : process
begin
wait for 1 ns; out1 <= '0';
wait for 1 ns; out2 <='0';
wait;
End process intialize;
End testBench;
    --- Quote Start ---
    The alternative is this:
    declare out1_int and out2_int as signals. do your read/drive then wire up out1 port to out1_int...
    You now can see what buffer is doing, it is meant to bypass the double work but causes confusion since it is meant to be output only (not input) but that can be read internally ???
    Future vhdl is meant to allow reading output ports without declaring them as buffer.
    --- Quote End ---
    I'm waiting for that new VHDL standard. It's just silly to not be able to read the output port, I think. But I still don't get why you should not use the buffer syntax? Except for the "tradition" for not using it, why is it not used by experienced?
    --- Quote Start ---
    --- Quote End ---
    Be prepared to wait a while. Vendors can be really slow at adding new standards to products. I know altera have started to support 2008, but only parts of it, and mentor hardly support any of it yet (which means being safely able to write 2008 compliant code isnt going to happen for a while).
    As for the out port question - I think you're looking at it from the wrong angle. VHDL does not have formal "parts" like register, tri-state buffers, multipliers etc. It is all implied using behavioural code. Therefore an out port is simply that - an output. It is the process that actually implements the register.
    I think thats why buffer is hardly used - it doesnt really fit in with the rest of the language.
