9 years agoHold violation on source synchronous clocks
Timing is failing with Hold time negative slack of (-0.098) when going from a 20MHz to a 100MHz clock domain (both clocks are synchronous and generated from the same PLL). This is a cyclone V design...
9 years agoI suggest to try the routing optimizations for hold timings if you have sync registers between the clock domains.
In my previous post I meant to use clock enable in the 100MHz domain synced to the negative edge of the 20MHz, thus you'll have 2/20MHz delay. However, this is a functional change and I don't know if it would have some impact on your design. Thanks, Victor
