11 years agoSebastion,
I am seeing the somewhat the same thing. I have inferred a Simple Dual Port RAM. Writes on Port A, Reads on Port B. Only one clock in this area of logic (200 MHz). TimeQuest flags a setup error between PORT_B_WRITE_ENABLE_REG and logic latching the RAM's output data. I have looked at the instantiation in Technology Viewer and Port B does not use a Write Enable (register is grayed out). I'm tempted to just ignore this (or declare it a False Path) and treat it as a disconnect between Quartus and TimeQuest. Did you ever find a reason for this behavior?
