13 years agohi-Z sometimes shown as 0
In Verilog If I have (in module section): output out_in; parameter A=2,B=3,C=4,D=5; reg [2:0]state; reg out_in; then in an always section: if (state == D) out_in = 1'bZ; else if (state == A) out_in = 1; else out_in = 0; then in the Waveform Editor, all the Z instances are shown as 0 (low level)? but if I use the following instead: out_in = (state == D) ? 1'bZ : 1; // only two conditions, I require three as described later then in the Waveform Editor, all the Z instances are shown as Z (darker, thicker line, mid way between high and low levels). Why is this?? If I have to use the "? :" instead of "if statements", is the following acceptable (i do not get any errors): out_in = (state == D) ? 1'bZ : (state == A) ? 1 : 0; as I require the "if", "else if" and "else" (three) conditions. thank you
