Hi, Have been able to add the qsys ADC module to the project but on final compilation the flow summary reports 0/1 ADC blocks in use even after I have selected all ports ANA1IN1 to ADC1IN8 in the qsys window.
- 6 years ago
Hello there ,
Here attached the screen shot and the modfied design file with ADC block utilization mentioned in the compliation report.
As of understood from the design you provided , quartus is optimizing the ADC block since it is no where used in the design.
In the modified design i instantiated the ADC input and clock as Input port which restrict the quartus to optimize the same.
Hope helps ,
Thank you ,
Sree
Here is the attachment of qar file .Can you try and let me know ?
Thank you ,
Sree
This is a project created by a blogger 'maximator' which once I edit to my design plans removes the ADC block for some reason. Can you send the project file specific to this query, please?
- SreekumarR_G_Intel7 years ago
I dont get you . I modified the project file which you sent to me . Please be clear what you really looking for . All the files related to the project file is already there in attachment.
Thanks ,
Sree
- AKohl37 years ago
That is not my project at all! Once I open it in quartus the following screenshot shows the different files similar tot the maximator project I mentioned. Can you please ensure the right project files?
hmm..Can you attach your project file again (Full project .gar format)?
Thank you ,
Sree
- AKohl37 years ago
attached here
- AKohl37 years ago
Looking forward to your reply!
Avdit
