Hi, Have been able to add the qsys ADC module to the project but on final compilation the flow summary reports 0/1 ADC blocks in use even after I have selected all ports ANA1IN1 to ADC1IN8 in the qsys window.
- 6 years ago
Hello there ,
Here attached the screen shot and the modfied design file with ADC block utilization mentioned in the compliation report.
As of understood from the design you provided , quartus is optimizing the ADC block since it is no where used in the design.
In the modified design i instantiated the ADC input and clock as Input port which restrict the quartus to optimize the same.
Hope helps ,
Thank you ,
Sree
Here is the screen shot of compilation report attached.
One thing I noticed that you dont have a RTL for enable the channel or reading the ADC channels , I added a test logic directly enabled the channel "0" , Channel Valid and Channel start. After that I could see in ADC resources in compilation report. I think since the implemented RTL is not using ADC /enable the ADC Quartus is optimization is not instantiating the module.
Sorry , I dont know how to attach the file here ,Here is the added logic in the top module for your reference ,
command_channel <= "00000";
command_valid <= '1';
command_start <= '1';
command_ready <= '1';
process (P_I_CLK100,response_valid)
begin
if rising_edge(P_I_CLK100) and response_valid = '1' then
data_to_display <= response_data;
end if;
end process;
Thank you,
Sree
- AKohl37 years ago
I added the above suggested logic but to no success. I even tried setting up a new project to double ensure the right part selection from the beginning, however I do not see the ADC module invoked neither the addition of the ADC pins in the final summary. Attached is the screenshot and top level module. I hope this is not a Quartus standard versus lite issue? And if the issue is not software related, can you send me the above depicted correctly compiled project+project files from your end?
