Hi, Have been able to add the qsys ADC module to the project but on final compilation the flow summary reports 0/1 ADC blocks in use even after I have selected all ports ANA1IN1 to ADC1IN8 in the qsys window.
- 6 years ago
Hello there ,
Here attached the screen shot and the modfied design file with ADC block utilization mentioned in the compliation report.
As of understood from the design you provided , quartus is optimizing the ADC block since it is no where used in the design.
In the modified design i instantiated the ADC input and clock as Input port which restrict the quartus to optimize the same.
Hope helps ,
Thank you ,
Sree
Hello ,
I get chance to look your design , Looks part you selected is not support the ADC features. Only SA and DA parts supports the ADC. Here is the link for device overview for page 5 mentioned in the part number selection.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_overview.pdf
when I open the IP in platform designer, i am getting error as mentioned "Error: max_ADC.modular_adc_0: The selected device part number 10M16SCU169I7G does not support ADC"
Can you use either SA or DA part to use the ADC feature ?
Thank you ,
Sree
