13 years agoAs you have found out yourself the generate is unfolded by compiler into that many processes.
Normally we can use for loop but because you can't put for loop ahead of process then generate is useful here. The actual purpose of generate is to tell compiler to synthesise or not depending on some condtions but here we borrowed it as loop that always generates
