13 years ago --- Quote Start --- Thanks Kaz, just 1 more question. 1) What does the following line do? Does it fills the signal with all zeros, regardless of the size?
:= (others => '0'); --- Quote End --- correct and if your vector is two dimensional then you can write := (others => (others => '0')); I hope now you will lit the leds and impress your teacher soon after holiday.
