12 years ago --- Quote Start --- In an async process, all signs must be assigned in ALL branches. In your code, LED_out is only assigned in the closed and opened states - it must also be assigned in all of the other states. The way to avoid this is assign all signals in an asynchronous process a default value before the case statement. This way, if it is not assigned a specific value in a branch, it will take the default assignment.
process(state)
begin
output <= '0'; --default assignment
case state is
when state1 =>
--do something
--no assignment to output means it will be '0';
when state2 =>
output <= '1'; --overrides default assignment
when state3 =>
--no output assignment, output is '0' again
end case;
end process;
This way latches are avoided. --- Quote End --- ------------------------------------------------------- Hi Tricky, thanks for the tips it worked. Wow!! you guys are good, but i got another hitch can figure out what happened: Error message when i tried the second time to compile it: Error (125048): Error reading Quartus II Settings File C:/altera_trn/VHDL_uppgift_4e/VHDL_uppgift_4e.qsf, line 41 Info (125063): set_global_assignment -name EDA_TEST_BENCH_MODULE_NAME "VHDL_uppgift_4e_vhd_tst " -section_id "VHDL_uppgift_4e_vhd_tst " Error (125022): Section identifier missing or not required Info (125063): set_global_assignment -name EDA_NATIVELINK_SIMULATION_TEST_BENCH "VHDL_uppgift_4e_vhd_tst -section_id eda_simulation" Info (125063): set_global_assignment -name EDA_NATIVELINK_SIMULATION_TEST_BENCH "VHDL_uppgift_4e_vhd_tst " -section_id eda_simulation Error (125022): Section identifier missing or not required Info (125063): set_global_assignment -name EDA_TEST_BENCH_NAME "VHDL_uppgift_4e_vhd_tst -section_id eda_simulation" Info (125063): set_global_assignment -name EDA_TEST_BENCH_NAME "VHDL_uppgift_4e_vhd_tst " -section_id eda_simulation Error (125080): Can't open project -- Quartus II Settings File contains one or more errors Error: Quartus II 64-Bit Hierarchy Elaboration was unsuccessful. 4 errors, 0 warnings Error: Peak virtual memory: 381 megabytes Error: Processing ended: Thu Dec 12 12:47:21 2013 Error: Elapsed time: 00:00:00 Error: Total CPU time (on all processors): 00:00:00 Is there a file i might not have added to settings > files > at the moment i just have the VHDL in place
