12 years ago
Help with Finite state machine
Hi guys, as an altera pupil i am still struggling with getting FSM to work properly i wonder if it is my testbench that has a problem or the code itself. This is the idea:
when key_0 is pressed let LEDG(1) light (on) ----closed state
when key_1 is pressed let LEDG(0) light (on)-----opened state
when key_2 is pressed let LEDR(1) light (on)------locked state
when key_3 is pressed it unlocks and enters into error state causing LEDG(1), LEDG(0), LEDR(0) and LEDR(1) to light(all on)
This is how my code looks at the moment
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity uppgift_dorr is
port( clk : in std_logic; --clock signal
reset_n : in std_logic; --reset signal
key_0, key_1, key_2, key_3 : in std_logic;
LEDR : out std_logic_vector(1 downto 0);
LEDG : out std_logic_vector(1 downto 0)
end uppgift_dorr;
architecture Behavioral of uppgift_dorr is
--Defines the type for states in the state machine
type state_type is (closed,opened,locked,error);
--Declare the signal with the corresponding state type.
signal Current_State, Next_State : state_type;
begin
-- Synchronous Process
p0: process(clk, reset_n)
begin
if( reset_n = '0' ) then --Synchronous Reset
Current_State <= opened;
elsif (rising_edge(clk)) then --Rising edge of Clock
Current_State <= Next_State;
end if;
end process;
-- Combinational Process
p1: Process(Current_State, key_0, key_1, key_2, key_3)
begin
case Current_State is
when opened =>
LEDG <= "01"; LEDR <= "00";
if ( key_0 = '0' ) then
Next_State <= closed;
else
Next_State <= opened;
end if;
when closed =>
LEDG <= "10"; LEDR <= "01";
if ( key_1 = '0') then
elsif (key_2 = '0') then
Next_State <= locked;
else
end if;
when locked =>
LEDG <= "00"; LEDR <= "10";
if ( key_3 = '0') then -- Låser upp dörren
elsif(key_2 = '0')then -- tray to lock, error
Next_State <= error;
else
end if;
when error =>
LEDG <= "11"; LEDR <= "11";
end case;
--end if;
end process;
end Behavioral;
The test bench looks this way:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY uppgift_dorr_vhd_tst IS
END uppgift_dorr_vhd_tst;
ARCHITECTURE uppgift_dorr_arch OF uppgift_dorr_vhd_tst IS
-- constants
-- signals
SIGNAL clk : STD_LOGIC := '0';
SIGNAL key_0 : STD_LOGIC;
SIGNAL key_1 : STD_LOGIC;
SIGNAL key_2 : STD_LOGIC;
SIGNAL key_3 : STD_LOGIC;
SIGNAL LEDG : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL LEDR : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL reset_n : STD_LOGIC := '0';
COMPONENT uppgift_dorr
PORT (
clk : IN STD_LOGIC;
key_0 : IN STD_LOGIC;
key_1 : IN STD_LOGIC;
key_2 : IN STD_LOGIC;
key_3 : IN STD_LOGIC;
LEDG : OUT STD_LOGIC_VECTOR(1 DOWNTO 0);
LEDR : OUT STD_LOGIC_VECTOR(1 DOWNTO 0);
reset_n : IN STD_LOGIC
END COMPONENT;
BEGIN
i1 : uppgift_dorr
PORT MAP (
-- list connections between master ports and signals
clk => clk,
key_0 => key_0,
key_1 => key_1,
key_2 => key_2,
key_3 => key_3,
LEDG => LEDG,
LEDR => LEDR,
reset_n => reset_n
clk <= NOT clk after 20 ns; -- 50MHz
reset_n <= '0', '1' after 100 ns;
init : PROCESS
-- variable declarations
BEGIN
key_0 <= '1';
WAIT FOR 50 ns;
key_1 <= '1';
WAIT FOR 50 ns;
key_2 <= '1';
WAIT FOR 50 ns;
key_3 <= '1';
WAIT FOR 50 ns;
key_0 <= '0';
WAIT FOR 50 ns;
key_1 <= '0';
WAIT FOR 50 ns;
key_2 <= '0';
WAIT FOR 50 ns;
key_3 <= '0';
WAIT FOR 50 ns;
WAIT;
END PROCESS init;
always : PROCESS
-- optional sensitivity list
BEGIN
-- code executes for every event on sensitivity list
WAIT;
END PROCESS always;
END uppgift_dorr_arch;
Can anyone help?
    --- Quote Start ---
    But somehow you have misscopied it (or modified it)
    There is an extra "begin" on line 97, and the first debounce process has (clk) as a sensitivity list when it should have no sensitivity list. Otherwise the code is the same.
    It also contains extra comments that Kaz's doesnt have either.
    I suspect you didnt copy it - you tried to merge it into your own copy.
    --- Quote End ---
    Now i deleted my old code and copied kaz's exact code, but i still have inferring latches see below:
    what code the problem?
    Info: *******************************************************************
    Info: Running Quartus II 64-Bit Analysis & Synthesis
    Info: Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Web Edition
    Info: Processing started: Thu Jan 02 14:39:19 2014
    Info: Command: quartus_map --read_settings_files=on --write_settings_files=off uppgift_dorr -c uppgift_dorr
    Warning (20028): Parallel compilation is not licensed and has been disabled
    Info (12021): Found 2 design units, including 1 entities, in source file uppgift_dorr.vhd
    Info (12022): Found design unit 1: uppgift_dorr-Behavioral
    Info (12023): Found entity 1: uppgift_dorr
    Info (12127): Elaborating entity "uppgift_dorr" for the top level hierarchy
    Warning (10631): VHDL Process Statement warning at uppgift_dorr.vhd(103): inferring latch(es) for signal or variable "Next_State", which holds its previous value in one or more paths through the process
    Info (10041): Inferred latch for "Next_State.error" at uppgift_dorr.vhd(103)
    Info (10041): Inferred latch for "Next_State.locked" at uppgift_dorr.vhd(103)
    Info (10041): Inferred latch for "Next_State.opened" at uppgift_dorr.vhd(103)
    Info (10041): Inferred latch for "Next_State.closed" at uppgift_dorr.vhd(103)
    Warning (13012): Latch Next_State.opened_380 has unsafe behavior
    Warning (13013): Ports D and ENA on the latch are fed by the same signal key_1_final
    Warning (13012): Latch Next_State.locked_365 has unsafe behavior
    Warning (13012): Latch Next_State.closed_395 has unsafe behavior
    Warning (13013): Ports D and ENA on the latch are fed by the same signal Current_State.opened
    Warning (13012): Latch Next_State.error_350 has unsafe behavior
    Warning (13013): Ports D and ENA on the latch are fed by the same signal key_3_final
    Info (286030): Timing-Driven Synthesis is running
    Info (16010): Generating hard_block partition "hard_block:auto_generated_inst"
    Info (16011): Adding 0 node(s), including 0 DDIO, 0 PLL, 0 transceiver and 0 LCELL
    Info (21057): Implemented 156 device resources after synthesis - the final resource count might be different
    Info (21058): Implemented 6 input pins
    Info (21059): Implemented 4 output pins
    Info (21061): Implemented 146 logic cells
    Info: Quartus II 64-Bit Analysis & Synthesis was successful. 0 errors, 10 warnings
    Info: Peak virtual memory: 479 megabytes
    Info: Processing ended: Thu Jan 02 14:39:24 2014
    Info: Elapsed time: 00:00:05
    Info: Total CPU time (on all processors): 00:00:04
    Adding the default assignment at the beginning of the p1 process:
    next_state <= current_state;
    removes the warnings.
    --- Quote Start ---
    --- Quote End ---
    Thanks Tricky and Kaz i am beginning to see some green light.
    The reason you get warnings is to do with the combinatorial process. A cleaner alternative is to use one state, since then all changes are on the clock edge. see code below.
    I also now believe my debounce counter of 18 bits is an overkill and I assume 10 bits may be enough. I also added a constant set to 10 for simulation and to 1000 for hardware debounce.
    library IEEE;
    use IEEE.numeric_std.ALL;
    end uppgift_dorr;
    signal State: state_type;
    constant max : integer := 10; -- 10 for simulation,  1000 for hardware
    signal count_0 : unsigned(9 downto 0) := (others => '0');
    signal count_1 : unsigned(9 downto 0) := (others => '0');
    signal count_2 : unsigned(9 downto 0) := (others => '0');
    signal count_3 : unsigned(9 downto 0) := (others => '0');
    signal key_0_d,key_0_final: std_logic;
    signal key_1_d,key_1_final: std_logic;
    signal key_2_d,key_2_final: std_logic;
    signal key_3_d,key_3_final: std_logic;
    begin
    --debounce
    process
    begin
    wait until clk = '1';
    key_0_d <= key_0;
    if key_0 = key_0_d then
        count_0 <= count_0 +1;
    else
       count_0 <= (others => '0');
    end if;
    if count_0 > max then
        key_0_final <= key_0;
    end if;
    key_1_d <= key_1;
    if key_1 = key_1_d then
        count_1 <= count_1 +1;
    else
       count_1 <= (others => '0');
    end if;
    if count_1 > max then
        key_1_final <= key_1;
    end if;
    key_2_d <= key_2;
    if key_2 = key_2_d then
        count_2 <= count_2 +1;
    else
       count_2 <= (others => '0');
    end if;
    if count_2 > max then
        key_2_final <= key_2;
    end if;
    key_3_d <= key_3;
    if key_3 = key_3_d then
        count_3 <= count_3 +1;
    else
       count_3 <= (others => '0');
    end if;
    if count_3 > max then
        key_3_final <= key_3;
    end if;
    end process;
    begin
       State <= opened;
       case State is
          when opened =>
            if ( key_0_final = '0' ) then
               State <= closed;
            end if;
         when closed =>
            if ( key_1_final = '0') then
               State <= opened;
            elsif (key_2_final = '0') then
               State <= locked;
            end if;
         when locked =>
           if ( key_3_final = '0') then
               State <= closed;
           elsif(key_2_final = '0')then
               State <= error;
           end if;
         when error =>
       end case;
    end if;
    end process;
    end Behavioral;
    --- Quote Start ---
    library IEEE;
    end uppgift_dorr;
    begin
    --debounce
    process
    begin
    key_0_d <= key_0;
    else
    end if;
    end if;
    key_1_d <= key_1;
    else
    end if;
    end if;
    key_2_d <= key_2;
    else
    end if;
    end if;
    key_3_d <= key_3;
    else
    end if;
    end if;
    end process;
    begin
       State <= opened;
       case State is
          when opened =>
               State <= closed;
            end if;
         when closed =>
               State <= opened;
               State <= locked;
            end if;
         when locked =>
               State <= closed;
               State <= error;
           end if;
         when error =>
       end case;
    end if;
    end process;
    end Behavioral;
    --- Quote End ---
    Thanks for all the help Tricky and Kaz. Everything is working prefectly with the Finite state machine now.
