18 years agoWithout seeing the design, I can't say for sure what is going on. I'm guessing you aren't getting the correct IO element connections. Using primitives in a bdf should look something like my attachement. This gets you the combout pin of the bidir IOE, which is what you want to drive the monitor output.
