13 years ago --- Quote Start --- I need help understanding how to use a FIFO in VHDL. If I am inside a process and I want to put two bits serially into a FIFO, how is that done? I need to set the FIFO clock enable high, the write signal high, set the input to the FIFO, wait one clock cycle, repeat it again with the second input bit, and then set the clock enable and write signal low. But that doesn't make conceptual sense with only having access to combinational logic within the process. I'm also assuming using one-shot multivibrators aren't used... --- Quote End --- To implement what you've described you need either a state machine or a simple counter. To illustrate the concept, here is a sketch of what the process would look like
process(Clock)
begin
if rising_edge(Clock) then
if (Reset = '1') then
Current_State <= Idle
Fifo_Write_Enable <= '0';
else
case Current_State is
when Idle =>
If (I_Got_Some_Input = '1') then
Save_This_Data <= Input_Data;
Current_State <= Save_First;
end if;
when Save_First =>
Fifo_Write_Enable <= '1';
Fifo_Write_Data <= Save_This_Data(1);
Current_State <= Save_Second;
when Save_Second =>
Fifo_Write_Data <= Save_This_Data(2);
Current_State <= Idle;
end case;
end if;
end if;
end process; The things to take away here are the following: - It takes multiple clock cycles to store the bits in the fifo because you want to serialize your data - The state machine is entered on each rising edge of the clock Kevin Jennings
